Workout data calcuation and export
Hi, what is the best way to accurately track workout data (e.g runs, walks) with the Pebble 2 Duo?
I’ve found the following:
  • the watch’s built-in Workout app is miscalculating run/walk distance and over-reports your distance
  • its not clear how to export the Workout data to any other app/computer. the google fit sync seems to only work sometimes if at all
related:
Set up Health Connect sync and use something like Heartwood, which lets you export a JSON or CSV. I haven’t had issues with this setup yet (my Time 2 regularly syncs with the Pebble app, which in turn syncs with Health Connect).
Have you set your height correctly in the Health settings? If so, I wonder if using another Workout app (e.g. Iron) might lead to better results.
Yes my height is correct, but I also had to enable Google Fit for Health Sync and now see Pebble data in there. Doh!
Will also try Iron, thank you!!!
