How do I export my data back out of the Pebble app ?
Ideally a CSV for things like step counts…
( importing it into Google is not a solution )
Currently there’s no such functionality
You can access and download your data using apps. I know Health Monitor + offers a .json option.
Is it planned ?
Speaking of which, is there a public roadmap anywhere ?
I’ve only had a PT2 a week and already there’s a half dozen paper cuts.
I haven’t seen a public road map. The only things I’ve seen are things Eric has said, scattered across Bluesky on Twitter.
I wonder what happens if I email Pebble and ask for an export… anyone tried this yet ?
Very interested if you are an EU-located user…
I don’t think the health data is stored in the cloud, so emailing would not help here afaik.
That being said, I am temporarily switching phones right now and not having the option to move my health data history with me is kind of annoying…
Of course it isn’t, I was wondering about data extraction and portability in the context of the quantified self movement.
It looks like there used to be an app to do this (by sending the data to a web API you could run yourself) , but it’s not been updated for heart rate, for instance.
Sounds like Yet Another Project I need to bank ![]()
It would be great to be able to export the health data from the Pebble app
Don’t know how much of a challenge it is though…
I found a semi-workaround for now that I thought would interest folks. If you install the Health Connect app (comes pre-installed on Android 14+, but I’m on a lower Android version), you can use the OpenVitals app to read that data (you don’t need the Google Fit app or whatever). That app is fully local (doesn’t even have internet permissions), so all of your data stays on your device.
I don’t know if Health Connect requires Google Play Services though, but if you already have it and just don’t want your health data synced online, this is a good option (that lets you export your data).
[edit] I can also recommend Heartwood which lets you export as a JSON or CSV (only thing OpenVitals lets you export is a PDF, which isn’t particulaly useful…). I also ran into rate limit issues with OpenVitals (looking at the bug tracker this seems to be specific to the standalone Health Connect app version rather than the built-in one in Android 14+) whereas Heartwood is working seamlessly.
Health Connect plus Heartwood seems a good workaround.
