Can't Force A Reset
I think I may have bricked my pebble.
I turn it of at night but because the "factory reset" option appears before the "turn off" option, I accidentally factory reset my pebble and it will not reconnect to my phone after many off and ons of my phone and watch.
Do I have a bricked Pebble now? When I try and hard disconnectit form my phone, I have no options. I just have a QR code on my watch - what can I do to save this?
Yeah I’ve done literally everything I can think of, including uninstalling and re-installing the pebble app. No luck.
Well… that sucks. (Not to whine)
That’s all I got no matter how many times I try and unpair from my phone/ force a reset by holding all the buttons on the watch itself. :frowning:
In the Pebble app go to Settings>Get Help>New Bug Report. Send us a note in there and we can help you out!
Or for quick help, check out 🏃 Pebble - Help and Getting Started | Pebble Help Center
Make sure you have unpaired in the phone bluetooth menu. That can stop it connecting if the watch reset it’s bluetooth settings after a factory reset.
Okay, awesome.
That worked!
Sorry for whining, I was more upset that I accidentally factory reset the watch. Sorry to bug you and @steve with a “don’t make me tap the sign” level troubleshooting question.
Thank you both!
