Time 2 (22mm) band recommendations for small wrists?
Does anyone with small wrists have a band they’re super happy with for time 2?
I have been scouring the internet for a short 22mm band that tapers 2-4mm. There don’t seem to be a ton of options around so I figured it might be a good question for the community.
In the box, from Pebble, you get a short strap and a long one. Do you need it shorter than the ones in there?
I believe my wrists are pretty skinny. The shorter of the two strap pieces that came with my Time 2 was a good fit.
That said, I bought an inexpensive fabric with Velcro strap for it. I’ll be happy with that type of band until I get one very wet I expect.
