Hi, folks! Waiting eagerly for my Pebble Time 2. Question: do we know the specifications of the strap, such that we could find or create alternative straps? I have a tendency to develop ganglion cysts and so I’m a little bit picky. AI search says that the Pebble Time 2 uses “standard 22 mm quick-release straps”, but the specs on repebble.com just say “22 mm”. Anybody know more?
Hey there! So the pins that come in our bands are “quick release”, meaning they have tiny levers that make it super easy to remove and reinstall your band whenever you want. Before quick release was a thing (on the Pebble Classic, for example) the pins didn’t have the lever and were just normal spring pins. So when you buy any 22mm band, just make sure it has pins that come with it or are installed into the band. Most do, but a “NATO style” (where the fabric goes over and under the pin and under the back of the watch) may not include pins. Feel free to reply with any URLs of bands you are eyeing and I can make sure they’ll work!
