Dear Pebble Team,I am a proud owner of the new Pebble Time 2, and I would like to share a small suggestion regarding the readability of the user interface.The text displayed in the system menus is, in my opinion, too small and thin, which makes it less comfortable to read. I also own the previous Pebble Time Steel, and the text on that model is noticeably larger and more visible. I would greatly appreciate it if, in a future software update, you could consider increasing the size and thickness of the menu text, or perhaps adding an option to adjust the text size.Thank you for your attention and for your continued work on improving the product.
Kind regards,
