Pebble Time 2- No sound
Hi everyone
I cant get any sound (notification, alarm)…
Nothing , only vibration.
I am missing something?
Souni isn’t used by the OS. Only apps that support it. Same for touch
Thanks. Hope next feature will support …
If you have a GitHub account, I would submit a feature request on the Core Devices Pebble OS repository. If you don’t, I can create a feature request for you.
the alarm app does use it now, but you have to manually set it per alarm
Thanks. I will check it.
I got it yesterday, the notifications worked just fine, today i am not receiving any notifications, tried to restart…
Too many issues…
Edit: i erased data of pebble app and reconfigure the connection, now the notifications is coming …
Hope they will fix it too
latest firmware PebbleOS v4.11.0 added the ability to set sound for alarm, but not yet for notifications.
