Hi, have been using Pebble nonstop since it was released - HUGE fan!
Request - can you please add the ability to turn off notification vibrations WITHOUT going into Quiet Mode? I want my notificaitons to disappear after 1 min, but also want to preserve battery and can make do without the vibration. As someone else mentioned, seems that there’s no way to add a custom vibration pattern of “none”.
It looks like “No Vibration” is now an option in 1.3.1.3 of the Phone app.
Sweet. I don’t think that’s the case in Android, but the app just updated. Where did you find it?
I found it on the changelog: “Add No Vibration options as Custom Pattern (thanks Federico!)”
I found it in the Android app under Settings (last icon along the bottom), choose Phone at the top, then Notifications. Choose Select next to Vibration pattern and the last option is “No Vibration”.
Woohoo! You’re a star! Did they just add that? I am pretty sure I checked when I set up my own custom pattern with minimal vibration.
Also, I tested to make sure that the alarms still vibrate.
Yes, v1.3.1.3 was released on June 5, but it may have taken a day or two to hit your phone.
