Hello all. I have a pre-release Pebble app called “Fit Tracker” that tracks running/biking workouts and creates FIT files that can be uploaded to Strava. The Pebble Companion app is used for the GPS, and the FIT file has location, time, pace, and heartrate information.
The Strava developer portal allows for NINE more testers if anyone is willing to try it out. Here is the link (the app is hidden in the Pebble App Store since I think it needs more testing)
The instructions are a bit wonky unfortunately. You will need to add your Pebble serial number at fit-dot-setpebble-dot-com, and then use this serial number when modifying the Fit Tracker settings in the companion app. After a workout, do a long press on the up button and choose to save your activity. You should then be able to see your activity in your account where the map is shown, and the FIT file can either be downloaded or uploaded to Strava.
The last remaining feature to add is activating the auto-upload to Strava. Currently you can view workouts on a map and choose to manually upload to Strava, but it is not automatic after you finish a workout.
Someday my ancient web site at SetPebble-dot-com will be replaced by the modern interface seen at fit-dot-SetPebble-dot-com, but that is a future project.
I am link-restricted to a single URL, which is why the “-dot-” are used in the descriptions above.
Here is a sample of a mapped run from fit-dot-setpebble-dot-com:
