Clangd compile_commands.json example
The SDK documentation is very straightforward and I’m really excited to develop my first pebble app. I use nvim and I love the LSP client so I’d like to use it with the pebble.h symbols. However, since the pebble cli tool is used to build artifacts, bear is having a hard time capturing the compile commands. My output compile_commands.json is empty.
I tried including the --force-wrapper and --force-preload flags to no avail.
the command should be as easy as bear -- pebble build.
omg I found the solution. I had to pebble clean first :person_facepalming:
