Hello, just looking at getting back into it and just trying test apps and loading one of my old watchface apps but if I try run and build I am getting the following error on both. Anybody with any advise please ?
-p pebble/emery
xsc main.xsb
xsl mc.xsa
Setting top to : /tmp/tmpixf6t1_m
Setting out to : /tmp/tmpixf6t1_m/build
Checking for program ‘webpack’ : /root/.local/share/pebble-sdk/SDKs/current/node_modules/.bin/webpack
Found Pebble SDK for emery in: : /root/.local/share/pebble-sdk/SDKs/current/sdk-core/pebble/emery
Checking for program ‘gcc, cc’ : arm-none-eabi-gcc
08:33:44 runner [‘arm-none-eabi-gcc’, ‘-dM’, ‘-E’, ‘-’]
Could not determine the compiler version [‘arm-none-eabi-gcc’, ‘-dM’, ‘-E’, ‘-’]
(complete log in /tmp/tmpixf6t1_m/build/config.log)
Build failed.
Running Moddable prebuild (release build).
Running mcrun -m ./src/embeddedjs/manifest.json -f x -p pebble/emery -t build -o ./build/mods/emery/mcrun -s tech.moddable.pebble
Copied Moddable mod for emery
Moddable prebuild completed.
INFO:root:Spent 0.000094 seconds waiting for analytics.
