I have this line at the top of main.c, copied from one of the example projects:
#include <pebble.h>
I get a warning in the CloudPebble IDE (a tooltip when hovering over the line of code):
gabbro, flint: 'pebble.h' file not found
This makes all the lines with pebble.h-specific types highlight red, with a similar “gabbro, flint” tooltip.
Interestingly, this does not affect the build, as I can build and emulate my project on the Gabbro and Flint targets without an issue.
Is there a disconnect between what the compiler is including, and what the IDE thinks exists for these platforms? Having all the pebble-specific lines highlighted red is not ideal.
Yes the syntax highlighting and static errors are kinda broken. I’ve also seen it highlight completely blank lines in red does restarting Cloudpebble work? Like closing the tab and reopening?
Unfortunately, closing and re-opening the tab did not fix it.
My current workaround is to disable Flint and Gabbro while I’m deep in the weeds developing, and only re-enabling right before building to test on those platforms. Thankfully, it’s only the Round 2 that has anything meaningfully different for my use case (a large, color, round screen), and those differences are easy dealt with by not hard-coding the geometry.
How can I tell the CloudPebble IDE where the <pebble.h> file is? It’s not in the App Source or Resources sections?
