Reborn cloudpebble is awesome!
I’ve been making use of the GitHub CodeSpaces recently with the new SDK and it’s been good but the lack of config support has been a drag. The new cloudpebble that is now live is awesome.
Latest SDK support (4.9.127), and config works! I had a small project on my TODO list that needed a separate per-platform Clay config and I knew it was going to be a pain to debug/test with my existing setup. The full working emulator in CloudPebble made this a quick 10 min job rather than an afternoon.
Whoever got this up and working, modernized and (hopefully :wink:) secured did an awesome job. If you end up in the Bay Area I owe you a beer/cocktail/smoothie/tea/coffee/insert-beverage-of-choice!
Only (slight) negative seen so far is the “Code completion unavailable.” message in the bottom right, which really is a minor inconvenience.
GitHub import worked great. Not tried updates yet.
Yup, code completion is not completed (as per notes CloudPebble Returns! Plus New Pure JavaScript and Round 2 SDK | rePebble Blog ) If someone else wants to add it, PR would be appreciated!
