Hi, I just got my Time 2 yesterday. Still setting it up fully, but one thing I noticed, the shake or flick to light up backlight doesn’t seem to work. Things I changed to test it:
- enable Backlight Motion
- disable Ambient Light Sensor
- disable Dynamic Backlight Intensity
- change Motion Sensitivity from Very Low to Very High, one by one
and no matter how much I shake the watch, it won’t light up.
I tested the Compass app and the accelerometer seems to be working fine. I also tried Reset to Default based on some comment on Reddit, and it seemed to work once, but I couldn’t reproduce it afterwards. Tapping the screen to light it, and using the buttons will light it normally. I’m on Android.
What could be the issue here?
SOLVED: it is now working properly after doing the three button hard reset and a regular reboot afterwards.
