Screen is frozen/stuck
I’m using an iPhone with the Pebble Time 2 that just got delivered. The pebble received a notification from Teams, and now the watch is stuck on the Teams logo. I can’t get it to move off that screen no matter what I try to do. There is no button press that I can do to get the screen to move off the Teams logo. Can I restart the device manually by pressing and holding certain buttons?
Here is a screen shot from the app of the watch, however in person the screen is purple and white. Not the colors visible in the screenshot.
I could really use some advice, currently I can’t use the watch at all.
Hey there, hold down the back button until you see the PebbleOS logo and your watch restarts. You just filled out a bug report, right? Claudio will be getting back to you shortly.
Yep, I just put in a bug report. Thank you! Restarting seemed to do the trick
