PT2 stopped charging
I’ve had a PT2 since May. It’s been working great with no battery issues. Charging for the third or fourth time since purchase and it suddenly won’t charge. Looking at a battery monitor app I can see that the is_plugged value from the SDK is returning true while is_charging is false. I’ve cleaned contacts with alcohol and tried various USB-C cables and wall adapters. Not sure what else I can try. Any help appreciated.
I’ve submitted a bug report via the app.
Great! I was about to ask you to. We’ll be able to get you sorted out don’t worry!
Bug report #9249. Thanks.
Cna you try holding down the left button for 10s until it restarts? If that doesn’t work, we can help you out on the bug report you filed.
Issue persists after restart.
I am also experiencing this issue. This would be my third time charging my PT2. Love the watch.
Cleaned contacts and restarted the watch with no success.
I am not sure about the states as I am no developer but have tried different cables that do work to charge other devices.
What a terrible issue. I turned it off and left it plugged in just in case. Now I can’t even turn it on the next day…
They’re shipping me a new charging adapter. Hope that fixes it!
I want to report back that the charger replacement did the trick.
I have exactly the same problem. My new PT2 from August is now down to about 5% and does not react at all after plugging on the charger.
Restart does not help at all.
Can one explain what type of charger this should be? Is this regular DC? Can I measure something?
In the meantime I found the problem. It was not the watch or the charger, it was the cable. Try different USB cables if you run into the same issue.
I have the same issue. wont charge at all. when i connect charger, screen lights up, but nothing after that happens.
How to summit bug report for this issue ?
There should be a bug report button in the Pebble app. I think it’s under settings, but I’m not sure.
