I have my Index configured to send reminders and notes to Tasker via a share, and functionally it’s working, but it does mean that the Tasker app opens and takes the foreground every time I make a recording. Is this preventable?
Hi! Thanks for using Index 01 and I’m glad the tasker integration works (kinda!). I’m not a Tasker expert or even a Tasker user. I built the integration blind. If you have any feedback that can help me fix this problem, I’m happy to implement it or if you are technically inclined, you could contribute a pull request to the github.com/coredevices/mobile-app repository
I’m not versed in Android Intents at all, but I think the issue should be reproducible by installing the Tasker app, creating and enabling a profile that activates on Received Share, then enabling the integration in the Pebble app and sending a recording.
