PebbleOS v4.33.0
Today I received the update notification for PebbleOS v4.33.0 for my PT2.
Change notes:
- Touch control is now enabled across the OS! (Thank you vuzvlad!)
- Touch screen should now work for people who had issues before (also fixes <5 day battery life issue)
- Heart-rate variability (HRV) API on Pebble Time 2 (thank you karthakon!) will be enabled in upcoming Pebble SDK release
- Alarm/notification sounds and mic no longer reboot the watch when the system is busy
- Fixed blank white silent notification popups
- Fixed battery drain from fast advertising sticking on after airplane mode
- Fixed left-hand mode Back+Up quick launch using the wrong buttons
- Health can be assigned to any Quick Launch button, with animations that match the launch direction
- SDK: emery/gabbro apps can now use the full 128 KB binary limit, was wrongly capped at 64 KB
- Various UI tweaks for Round 2
- Many, many bug fixes
Awesome to see that HRV getting added to the Pebble Time 2. After the Pebble SDK is updated, will users be able to see that in their the Health tab of the app?
Crickets…
And the Android app has updated too, but the release notes don’t list the new version.
Does anyone know if touch screen can be disabled? Thinking about putting a new firmware in but I’m pretty sure I don’t want touch screen
There is an option to disable the touch screen
Trying it out now. Will keep touch on.
