Option to Turn Off Motion Backlight While Sleeping
Wouldn’t it be smart to have the option to turn off the motion setting for the display light during sleep mode? I mean, when I’m sleeping, I don’t want to be blinded by the light from my Pebble when I move my hand.
Every evening, I turn off my light manually on the clock. It’s annoying.
There is an option called Quiet Time. On your watch, go to Settings, Quiet Time, then set a schedule for when you usually sleep. To quickly enable Quiet Time, I go to Settings, then Quick Launch, then choose the back button (long press) to enable Quiet time manually.
That doesn’t disable the backlight
My error! I guess I sleep pretty sound.
Nevertheless, a solution here would be great.
This setting could easily be integrated into Sleeptime.
Yes please! In iOS I can setup a bed time. This is synced to my Apple Watch. This makes Apple Watch to only activate the screen when I tap it.
