I’m looking forward to using the Index Webhook functionality.
I have a couple of technical questions about the ‘correct’ way to handle my Webhook interaction.
Ideally, I’d like it if a ‘successful’ (2XX) call to my Webhook means no other actions occur (e.g. no local notes or reminders created/updated because the Webhook has handled it) - is that how the Webhook implementation works?
Could you also clarify what happens if my Webhook returns a 4XX/5XX code? For example, will the Pebble App ‘retry’ the Webhook under any circumstances? Will that ‘failure’ be surfaced anywhere? Obviously my Webhook will be doing its own error handling, but I’d like to better understand when/what I should let the Pebble App know about (and when/what I should ‘silently’ handle at my end).
Thank you for any detail you can provide.
