Using Hermes with Index 01
In one of the pre-release videos, Eric mentioned that he uses Hermes with his ring. I’m wondering if anyone has this set up. It looks like Hermes doesn’t support exposing it’s tools as MCP over HTTP by default. I know it’s possible to spin up something custom with FastMCP but I’m wondering if anyone knows of an existing solution.j
Hermes accepts inbound webhook pushes, and Pebble Index supports sending recording data to any HTTP endpoint as a webhook:
  1. Webhooks | Hermes Agent
  2. Index Advanced Features (MCP, Webhook) | Pebble Help Center
Thanks for the reply! I should have mentioned in my original post that I’ve been using this and it works quite well but it would be nice if I could send only to the webhook instead of also having the regular/default model running. For now, the “duplicate effort” is fine, though.
If anyone is coming across this and wondering how to set it up, I’ve written a blog post, which you can give to an agent as a reference for something that works: Integrating the Pebble Index 01 with my Hermes Agent | Kevin Lewis
