Index Webhook API
Current Webhooks Help documentation states: “Currently, only a single webhook can be configured.”
Current INDEX_WEBHOOK_API.md ## Setup API documentation states: “Each gesture has its own endpoint, headers and payload mode”
I’m fairly sure at one point (before I got my Index 01) that I was able to set up an endpoint-per-gesture, but this now seems to have gone away in the latest Phone App?
Any timeline on when it might come back?
Also, +1 for Only Button Press Events for Smart Home
You can definitely set up two distinct webhook destinations. There’s dropdown for ‘Hold and Talk’ and ‘Double click and talk’ that can be routed to different webhooks.
Thank you, @Eric - I have found it. BTW, the Index 01 is just brilliant - when you said “it changed your life” I can now see where you’re coming from!
For others trying to set this up, the ‘Settings - Advanced - Webhook’ option only showed me one web hook (hold & talk) - individual gesture endpoints can be configured by scrolling beyond the ‘Nothing’ option (which I couldn’t see on my phone until Eric pointed me in the right direction).
Good point. We should probably move that above nothing!
Why not Two clicks and a hold? Etc. The Index can register a bunch of clicks (e.g., SOS).
