Do any old chargers work with PT2?
Do any of the old chargers work with the PT2?
More specifically, I have an old kickstarter Pebble Time Steel and charger, would that charger work with the new PT2?
Why ask? I have a nightstand lamp/charger with a spot for watches that currently is wrapped up with that old charger. If I can use that with the PT2, great. I can then use the puck for travel. If not, well, then I’ll figure something else out.
Yes, all but the Pebble Classic and Pebble Steel chargers will work
Is there an easy visual way to tell compatible with not ?
This is the Pebble Time chacger, one that’s compatible with tme new watches. It’s wore recnangular and has no divider between the middle pins.
This is the Pebble Classic charger, it’s rounder and has a divider.
Many thanks for the answer and showing the difference in chargers, been a great help
And the pitch between the pins is 2.8mm right ?
