CloudPebble to GitHub Link Not Working (?)
I get “an error has occured” whenever I try to set up CloudPeble to sync with my GitHub repo. It’s able to pull it in for initial import just fine, but can’t pull/push (or even set up to) after that. Known issue or am I doing something wrong?
-Sterling
I guess the Feb 20th blog post mentioned this wasn’t working yet, so seems that’s still the case and it’s not just something I’m doing wrong.
Just confirming that you are signed in to the SterlingEly account under https://cloudpebble.repebble.com/ide/settings? If you’re still facing a problem like that, it would be helpful if you could post on the GitHub issues for CloudPebble - github.com/coredevices/cloudpebble/issues
Make sure the cloudpebble repo sync is installed and has access to the repository.
Ah, when in doubt, “turn it off and on again”. I was indeed already signed in, but unlinking and re-authenticating did the trick. Thanks y’all!!
