Hi, I have an old Kickstarter Pebble 2 HR and today wanted to migrate from the old Pebble app to the new one. I developed a custom watchface that I’m planning to publish, and wanted to upload it to the pebble, but I don’t see as available the old direct connection method, only one using a login. On the pebble app I was logged in with google. On the cli running the pebble login command i get this error while loggin-in with google: {"error":"Flow not found or expired","code":"FLOW_NOT_FOUND"}, but if I try to login with Github i get this other error: This email is already linked to a different sign-in method. Please use the original provider first, then retry.. How can I solve the situation?
Try signing in to this website first Developer Sign In and then use pebble login with your gmail
Should be fixed now!
It’s working fine now, thank you!
