CloudPebble may need another look after update
I am having an issue where using the three menu buttons causes the face I had showing to switch to another face in my list. I had not seen that previously.
Someone was kind enough to check out my code and found it might be an issue with CloudPebble builds.
kilrah
5h
I built your source locally with the latest sdk and it’s working normally, while with the store version it did revert to my previous watchface so I’d suspect it’s something wrong with cloudpebble’s build
All the different cloudpebble pages use the same instance of the emulator. You can try clearing your browser cache to see if that clears up the issue.
Opera wouldn’t get past the sign in to CloudPebble, couldn’t deal with the pop-ups for sign in and such. Don’t use Opera much anyway.
Chrome signed in fine. I did another build for version 1.6 and that seems to have dealt with the issue. I changed no code, just went in, changed the version, and did Publish. So far it passes the “look at my calendar and see if the face comes back up” test.
