I am working my way through the CloudPebble tutorials and am stuck n pArt 2 Customizing Your Watchface. I have exact same code as the example on github and have downloaded the true type font from there too. When I build I get the following error … Any ideas ??
Traceback (most recent call last):
File "/root/.pebble-sdk/SDKs/current/sdk-core/pebble/.waf3-2.1.4-e7394e338829ca9f0f1b029a38b80f7a/waflib/Task.py", line 179, in process
ret=self.run()
File "/root/.pebble-sdk/SDKs/current/sdk-core/pebble/.waf3-2.1.4-e7394e338829ca9f0f1b029a38b80f7a/waflib/extras/generate_resource_ball.py", line 13, in run
reso=resource_generator.generate_object(self,self.definition)
File "/root/.pebble-sdk/SDKs/current/sdk-core/pebble/common/waftools/resources/resource_map/resource_generator.py", line 97, in generate_object
return cls.generate_object(task, definition)
File "/root/.pebble-sdk/SDKs/current/sdk-core/pebble/common/waftools/resources/resource_map/resource_generator_font.py", line 52, in generate_object
font_data = cls.build_font_data(font_path, definition)
File "/root/.pebble-sdk/SDKs/current/sdk-core/pebble/common/waftools/resources/resource_map/resource_generator_font.py", line 69, in build_font_data
font = Font(
File "/root/.pebble-sdk/SDKs/current/sdk-core/pebble/common/tools/font/fontgen.py", line 114, in __init__
self.face = freetype.Face(self.ttf_path)
File "/root/.local/share/uv/tools/pebble-tool/lib/python3.11/site-packages/freetype/__init__.py", line 1192, in __init__
raise FT_Exception(error)
freetype.ft_errors.FT_Exception: FT_Exception: (unknown file format)
