Trouble with my repo / watchface
I started a watchface based off of a example, and I can build it locally, but it does not work to import it into cloudpebble. I keep on getting the following error: Error: ‘No file was found to satisfy the manifest filename: fonts/Jersey10-Regular.ttf’
Any ideas on how to fix this?
Thanks
Can you attach a zip of your project folder?
I had this issue too, I’m not actually sure what fixed it. I deleted the node_modules folder and re-zipped it and it imported fine. I don’t know if it was because I deleted that folder or if it was because I re-zipped it from Linux though
GitHub - epl692/pebble-potsface · GitHub is the GitHub for it. It’s pretty simple, just is supposed to let me know if my hr jumps by too much to quick.
I downloaded the repo as a zip file, deleted the node_modules folder and the build folder, zipped it again and Cloudpebble was happy with it.
It also works if you remove the node_modules and build folder from source control, I was able to import my own fork of your repo directly from GitHub into Cloudpebble as well.
Thanks for the report @epl692! I just fixed the underlying bug, so importing will skip those two dirs.
Awesome! One last bug I found, so, I was able to clone the repo, build the watchface, and make changes, but now I can’t push the changes back to the repo.
Error:
Error: 404 {"message": "Not Found", "documentation_url": "https://docs.github.com/rest/git/refs#get-all-references-in-a-namespace", "status": "404"}
Just as a general tipp: node_modules and build folder do not belong into git. So please delete it and add it to your .gitignore file (which will be commited and pushed). :slight_smile:
Sample .gitignore file (must be place in root dir):
build/
node_modules/
Just pushed a fix for this. Could you try it again, please?
