I have a PT2 and an Android phone. When using the “BabaIsYou” watchface by FouzR, none of the settings that I alter in the settings menu get applied when I click the “Save Settings” button. The settings get saved in the menu, but the watchface doesn’t change.
The watchface was updated as recently as April 26th, so I’m assuming this is an issue with my phone/watch and not the watchface itself.
Does anyone know what might be happening? Can someone try the BabaIsYou watchface and see if they can get settings to apply? Is there another watchface with settings I can try to rule out the watchface being the issue?
Hi there, doesn’t work on my watch either. I tried their other face “Seiko-data” and those settings moved over. You can actually contact the developer from the web app store! Keep us posted!
I’m also noticing that the battery and temperature blocks aren’t updating. Temperature is stuck at 000 and battery just shows “–”. Is this a related issue?
Also @Trevor is there a way to link or have an easier way for people to find my forum account instead of only having a direct dev-contact from the store?
