Watchapps to check out?
I confess that I don’t use enough apps on my Pebble! Lately I’ve started using the Claude app (Claude - Pebble Appstore), it even supports custom MCPs!
Do you have any favorites that we should check out?
Timer+ is super helpful for any random thing you need to time. But I was encountering a random bug which caused the watch to reboot if it was running in the background, started vibrating upon completion, and I had an active notification around the same time. Will be interesting to see if that still occurs with the new watches. Timer+ - Pebble Appstore
1000022273
One of my favorites has always been the classic Big Calendar App:
Shows public holidays, dates for upcoming and past months, and even the weather for some reason!
  • Skunk: all sorts of barcodes in the watch, so you can authenticate into the gym, starbucks, preferred customer programs, etc. Fun fact: watches with OLED screens also have it, but Pebble’s reflective screen works a lot better than OLED with barcode scanners.
  • Authenticator: 2 factor authentication/TOTP in your wrist, for websites that require it.
Checklist is great - voice notes/TODO list
QR Generator is a good alternative to Skunk
Skipstone can be useful if you have a supported device/backend. For media control
HTTP Push is pretty great. Call REST end points from a menu
@atomlabor made recently an entry into the pebble world and keeps him self quite busy.
PureNAVI
Final RUN
… got one watch face already in store and one on the way as it seems.
check out gitLAB here:
EDIT: after checking out his blog (here), he is not that new to Pebble, still great work @atomlabor
Thank you very much, for the feature.
… and yes I agree with you the the OG Pebble Steel should be considered as a piece of art or as you stated “… und das Design ist zeitlos”.
Oh, I bought a used Pebble Time the other day. You have to see how your own apps look on real hardware. And if Eric hurries up ;), then I’ll be able to test the T2 live soon.
For me, it’s the Multifunctional 7 segment watchface. While I could load the settings page in the Rebble app, it wouldn’t load in the Core Pebble app. Mercifully the code was on GitHub so stillmanff forked it and hosted it himself so it still works!
Three of mine — and I should say first that they are Pebble Time 2 only.
TTMM Alarms — eight alarms with 24 coloured tags. It wakes the watch on its own with the app closed and rings full screen, through the speaker.
TTMM Timers — eight intervals you keep rather than a stopwatch you start and forget, tagged for home, sport and cooking.
TTMM Codes — a small vault for numbers you come back to; short ones stay visible, the rest sit covered until you tap, with three levels of protection behind a PIN.
What they share is that everything is set on the watch itself — no companion screens, no account, nothing leaves the wrist. $2.99 each after a free trial, and they install from TTMM Stream, my own appstore source: apps.ttmm.is
