Random vibrations
I have a Pebble Time 2 and I use Android 13. My watch likes to vibrate at random times. When it does that, I look at it right away and there is just the watch face, no other apps appear. Is there a way to stop it?
Is it a watch face that vibrates on the hour? Or vibrates when you possibly lose connection? What’s your current watch face now?
The current one is TimeStyle but it does it on every watchface I have. Also I have the hour vibration off.
Don’t know about this face but many will vibrate upon loss of connection with the phone. They will usually show that connection is lost in some way so you could check.
It does it when I’m sitting right next to the phone. There’s an update for the app, so I will run that and see if it helps.
Nope. Still getting the random vibrations.
Same issue on my PT2. I have both “Hourly Notice” and “On Disconnect” disabled. I use the “Straight” watchface.
OK, I believe in my case the vibration was caused by the watchface. The “Straight” watchface has its own “Vibration on Disconnect” (which was enabled).
Do you have the “purr” app installed? To my knowledge, random buzzes are what it does.
Nope. No purring.
I think it is the watchface too. TimeStyle is the name of the one that just randomly vibrates. Also Phoenix Big and Last Time.
If I’m waiting for a text from someone I make sure it’s on a different face or if I don’t want too be disturbed.
