Phone battery drain
Hi, I got the PT2 just 10 days ago. So still playing, testing and learning a lot… with the watch battery looking pretty good so far, the drain on my phone battery is huge! The pebble app on my phone is by far the biggest battery eater, even when I don’t actively use it (ie. it is only in the background). That shouldn’t happen for a watch app!? I have a Samsung Flip 6.
Barely using anything here, maybe something crashed?
I don’t have any issues with the app. So, it doesn’t look like anything crashed. It just drains the battery life a lot.
Could you do me a favor and fill out a bug report in the app? Settings > phone > get help > new bug report
I was just about to do the bug report when I realized that the app wasn’t sucking the battery anymore. Maybe there was an update these days which solved the problem? I’ll wait a bit and if it’s draining the battery again, I file a report.
I have been enjoying my new pebble for about 3 weeks but since I started using it with my Pixel 9a, my phone battery needs recharging 3 times a day. The pebble app doesn’t seem to be high on the list of apps using battery so I am not sure how to sort out the problem or identify whether it is related to using the pebble app. Any ideas?
It turns out shutting off Bluetooth most of the time solved the fast battery drain I was experiencing. The android battery settings that let you look at per app battery use didn’t identify this. I don’t know if there is a better way to deal with it but for now turning off Bluetooth most of the time works. When i turn it back on briefly, the watch and the phone seem to catch up.
I also have a Pixel 9a and I do NOT have this problem. I charge my phone once a day and it is usually around 50% when I charge it. I do not get a lot of phone calls or emails or text messages a day.
Hugh
Interesting. Do you use the stock android for your os? It shouldn’t make any difference I am told, but I use grapheneos.
I am using the stock Android 17 on my Pixel 9a.
I have a Pixel 7 Pro with stock Google Android and also no specific battery drain since having my new Pebble. You may want to open a bug report in the App so they can check if there’s something wrong on their end specific to your device.
I use a Pixel 9a with Graphene OS, too, with my old Pebble (I’m still waiting for my Pebble Round 2), and the Pebble app with Bluetooth enabled. No battery drain, charging the phone every second day is usually sufficient.
