Battery life on PT2?
Hello,
Now I got my Time 2 from 2 weeks. But his battery life is around 2 days… It’s change between my old Pebble Time…
I saw my Time 2 charge in 1 hour. So is it correct ? I don’t know is I have a battery issue, or another issue.
Thanks for your help.
Hi there, could you do me a favor and send in a bug report in the app? Head to settings > phone > get help > new bug report. Thank you!
The Time 2 average is currently around 17 days. So nowhere near the promised 30 days but still significantly more than 2 :sweat_smile: I think tde Pebble app has some webview that shows your battery stats, maybe thah would be helpful in figuring out what’s draining the battery so much? If you’re using a very animated watchface that could lead to high drain. It’s also possible you’ll just have to charge it a few times and it’lr become normar :person_shrugging:
Thanks for your help. I send report.
I found also the battery page, I’m surprise because the backlight represent 67%… Yes I setting the backlight at hight level (remove dynamic, put high level, put 8s on) . I love light^^ I don’t imagine it was backlight the issue…
I hope the report can explain me…
But when i saw the drop graph, I don’t saw difference between the day when I use it, and the night when I don’t use it. The battery drain identitically the day and the night…
