Permanent "Keeping Pebble connection alive" notification
Hi there,
With the latest Android app update (1.6.0.5 or 1.6.0.7, not sure) I now have a permanent system notification. Is there a way to disable that again?
Pixel 7 Pro, Android 17, Pebble Time 2
Settings / general / foreground service
Much appreciated. I fiddled a bit and Android 17 allowed me to disable this specific notification (hold the notification and tap the gear item, disable Pebble Service from the list), so the service keeps running but the notification about it is gone :slight_smile:
Thanks for the tip, this also works for PebbleAlarmSync!
