Pairing and Usage issues with iPhone Duo or perhaps latest updates?
My Index01 had been working fine with my prior iPhone 17 Pro Max. I recently updated to the Duo. Firstly, pairing the Index 01 has been a challenge. After numerous resets (SOS on the ring), app deletion/reinstallations, and phone reboots, I think I finally got the ring paired. However, recordings seem to only transfer if I manually open the app and/or manually connect to the ring from the phone’s BT settings. I could be wrong (and frequently am) but I thought the ring paired via BTLE on the 17PM but this time it seems to be paired via BT Classic and doesn’t reconnect quickly or easily.
Has anyone else experienced challenges pairing and using their Index 01 with a Duo? Could this be unrelated to the Duo and be something related to recent firmware or app updates? Either way, the ring is not working very well for me at the moment since I have to manually extract recordings.
BTW, I already submitted a bug report from the app but figured I’d ask here to see if it’s just me.
TIA!
Is your old phone nearby and still paired to Index 01? Otherwise, we’ve got your bug report and will check it out!
Hi! Nope the other iPhone has been factory reset and mailed for sale so it’s not nearby.
It sounds like possibly it’s connected as a regular BT device, instead of a BT companion device through the Pebble app? Not sure how iOS does things but if it’s like Android in that regard, whatever issue that’s preventing you from connecting through the app is likely the culprit for the weird BT behaviour
Yeah, that’s what I thought as well… that it was paired as BT Classic vs. BTLE, but there was no choice during setup so it paired the way the app did it. The Duo does have the new apple-designed wireless chipset in it so perhaps there’s a weird quirk which I why I mentioned it.
AFAIK the ring only supports BLE. But there’s a special status you can connect with, as a companion device that affords special permissions
In my list of BT devices on my Duo, I see “Pebble Index XXX” as “Not connected” and interaction with the Index doesn’t change that status. The detailed info for this BT item only has an option to forget the device, and tapping the item to force a connection to it fails every time. Even if I have tapped the Index’s button to wake it up. Sometimes using the ring will illicit a response and others I have to try connecting to it via the BT menu and then it connects and offloads recordings even though the BT item’s status still says that it’s not connected.
BTW, one other small thing to mention… when installing the app fresh and choosing to log in with Apple, I have to do so typically 3x before it is accepted and the app logs me. I can select “Apple ID” as the login option, then a dialog opens to select my account and authenticate. That dialog is confirmed and closes but the Pebble app remains at the screen to select the authentication method. I repeat this usually 3x and then the app logs me in.
