Nightscout Pebble Watchface
Will the Nightscout Pebble Watchface work well with the upcoming Pebble Time 2 or does it need adjustments?
I suppose it will operate perfectly as is but the part
Existing apps/faces will show up with a border on Pebble Time 2 until developers update them, since it has a larger display (200x228 vs 144x168 pixels). Read more about on the old Pebble dev blog.
in the introductory blog post made me a bit skeptical.
There is an option to scale the app/watchface to fit the higher screen instead of doing letterboxing. It might look okay like that. But also it’s open source so it should be pretty straightforward to update it for the large screen.
