tudza
May 7, 2026, 11:07pm
1
I used the Publish button in CloudPebble because I hadn’t seen any other way mentioned for getting faces onto a watch.
Is there an alternate way to sent watchface code to my Pebble Time 2? Is there a way to make a face published on the App Store private?
jpx
May 7, 2026, 11:20pm
2
In CloudPebble under “Build & Run” you can select phone and then use the cloud dev connection to install your watchface
tudza
May 7, 2026, 11:43pm
3
Figured it might still have to go through the phone. I’ll have a look.
Thanks.
tudza
May 8, 2026, 12:22am
4
Well, I enabled the Dev Connection on my phone
I think I’ve connected on the web page
Still just sits and spings
Axel
May 8, 2026, 4:45am
5
Another way. Open CloudPebble on your phone’s browser. Download the pbw file and open it with your Pebble App on the phone. This should install your app on your watch. This is my way for private watchfaces, I’m using Android.
tudza
May 8, 2026, 5:27am
6
Thanks, I’ll give it a try if I decide to make a third face.
tudza
May 14, 2026, 10:23am
7
Worked first time.
Thanks for the information.
tudza
June 1, 2026, 9:47am
8
OK, I used the drop down just now to select New Cloud Dev Connection. Didn’t try this before.
With that selected things worked as expected and the watch face appeared on my watch.
