I was going through the Cloudpebble samples and managed to get the fonts I wanted, changed colors to black and white, added a different time display, and changed the date format displayed.
I’m at this part now:
because I want to display a simple battery level bar.
I copied and pasted the code samples where I thought they should go, but it doesn’t work.
It would be nice if I could find the main.js of the sample with the battery level parts in it.
A ha, I see the complete code is available through a link to Github. I’ll look it over and try again.
Meanwhile, this is version 1.2 after I fixed the padding on the UTC Beat time line.
