Change background to white?
Is there a way to change the background to white on the PT2? It only gets to blue on mine.
Thanks in advance.
The “blue” is a side-effect of the RGB backlight’s blue and green LEDs being stronger that the red one.
RGB backlight control just rolled out to the watchface/watchapp API, and there are already a few watchfaces that will let you adjust the color. (shameless shill, Rombra lets you do this).
It’s only a matter of time that the RGB backlight is adjustable system-wide. The Android experimental app allows you to change this setting already.
Okay, thanks for responding so quickly. I will wait patiently for this to all work out.
Thank you.
