"Shake Twice" Quick Launch
Is it possible to enable a quick launch on a double shake? So you shake the watch, the lights turn on. And in that time window, for example 15 seconds lights on, when you shake the watch again, a quick launch is…well, launched. Should be easy enough, right?
I got the idea because whenever I get a notification, I have it fade away quite fast. BUT sometimes I want to check the last notification again at a glace. My other hand full, wouldn’t it be great if I could double shake my watch and see the last notification…or any other action of course.
I guess my question is, how would you avoid accidentally triggering it doing other stuff? I trigger the shake to wake by accident all the time.
Maybe in addition to that we should have some adjustable parameters on how the wrist flick is detected.
