I’d like my reminders to be sent to me as telegram messages so I get them on my computer as well as my phone. I rarely check my phone. How can I do this?
Telegram has a bot API that let’s you send messages via a web request
https://stackoverflow.com/questions/31197659/how-to-send-request-to-telegram-bot-api
What would I use that for? Looks like the webhook setting in the app sends the “recording data” after each recording rather than the generated reminder.
Oh wait you mean you want to be messaged via Telegram at the time of the reminder? That would require some sort of server. Your phone could run one, or maybe there’s already a service that lets you set reminders through Telegram and you just have to push reminders there
I have a home server that can facilitate all of this I just need to know how to get the pebble app to fire something off when it does a reminder. I don’t think that functionality exists
Looks like I can set up tasker as an account. That could work. I don’t have google play services on my phone so I can’t install tasker unfortunately.
I think your best bet is to set up an MCP server on your home server. You should be able to set it up to route reminders to that server, then you can handle scheduling the messages from there.
Can totally be installed and functional w/out play services.
Purchase directly from the dev’s patreon
Thanks I did end up doing that. I think that’s the solution I’ll go with for now. Might switch over to MCP if I can stop being annoyed with it long enough
