Create a different note from index 01?
I was reading the FAQ and the instructions and I don’t see an answer, but maybe I am just thick? Can I create a new note from speaking to the ring?
I know right now if I have notes to self and another note I created in the app called network, I can hold the button and say “add to network, check for updates to OPNSense.” The note will appear on the network note in the app, not notes to self.
However in my brief tests, I cannot seem to say “Create new note called network and add…” This will end up in notes to self as an entry.
Is there a special code word like Shazzam! or Wa-Wa-Wa-Wa Wonderwheels! that I have to say before so that the app creates a new note instead of adding to the default?
Right now you can’t add a new “list” in a recorded command. You would have to make that manually then add to it!
