Hi, I am developing JavaScript watchfaces using Alloy, and I have hit a bit of a wall trying to take advantage of poco.blendOutline to render an outline.
I tried to build a project with import { Outline } from "commodetto/outline", but the debugger revealed that the import fails with a runtime error when the module commodetto/outline is not found.
The Commodetto docs for Outline say to update the manifest to include manifest_outline_poco.json, which no longer exists. Browsing through the Moddable github examples I see random-ellipses which has a manifest that references "$(MODDABLE)/modules/commodetto/outline". When I try that, pebble build informs me that modules can’t contain native code, and it hints that I might have meant to build with mcconfig.
What am I missing? Are my only routes for using Outline to convert my watchface to piu or abandon JavaScript in favor of C?
