Removal of Sandboxes and killing my use case
Yesterday I noticed something odd when I was trying to add a note to my home notes system, it’s a custom Obsidian vault setup so the standard obsidian integration doesn’t work for me so I built an MCP.
Over the past few months my MCP has grown to include other tools such as a To Do recorder that puts things into my backlog, the ability to query my daily notes and the ability to send anything else to my home assistant assist pipeline which has logic that handles every other use case.
So here’s my setup up until yesterday.
Single-Click-Hold using the standard reminders and to do functionality to record shopping list and things I need to get done that day with a fallback to general notes so I don’t lose anything.
Double-Click-Hold routes to my MCP, To-Do’s go to my vault backlog, get sorted automatically for the future, notes go to my custom daily note in the right sections dependign on keywords, Turn on lights or anything else hits my Home Assistant. It’s been working great.
Yesterday, I went to add some notes, the app told me they were in the app notes, I went to add some to do for a future project, they landed in the app to-do.
I went and investigated what was going on and I came across this Reddit post, then double checked my app.
No more sandboxes, no way to route my different clicks to different tools, no way to have my fallback work the way I want, my workflow is now dead.
The temporary workaround is to disable all the tools for the Index Agent except my MCP losing the local functionality.
I can find no blog post or information that this was an upcoming change, I can see no logic to this except now you can have the request go straight to a webhook.
Please make my ring useful again.
I have raised a bug report as I was told before that htis was the right way to send feedback but I’m putting this here so others who might be having similar issues can find it.
Please post here to help get more visibility [regression] Index MCP Sandboxes have disappeared, no ability to associate gestures with MCP tool sets · Issue #465 · coredevices/mobileapp · GitHub
