Killed my Index 01
All right, guys, after two months and three days, I finally killed my index 01. I knew that I would put it through the ringer. I’m a registered nurse and I wash my hands hundreds of times a day, often with hand sanitizer.
About three weeks ago, I noticed that the rubber or silicone on the ring was starting to peel off. I was sure that would do something with the water resistance. This morning, with the rubber almost completely peeled off, it started registering that I was pushing the button when it was just staying still on my nightstand. I think that was the end.
I did the endurance test so that we could better understand how this product would face real life situations, knowing exactly what would happen in the end. I love this product. I had a lot of fun using it, and I was able to create some really fun notes on the fly. I’m officiating a wedding, and it helped me get real-time thoughts down into somewhere I could refer to while writing the ceremony. That was my best use case.
I think moving forward, the index 02 would have a lot of potential if it was able to be used used under rougher conditions, like for a nurse. This is a great tool for someone in my profession, and with the security and the privacy, it makes it even better to use for just common tasks that we do and reminding us when to go back in a room or check something. Thanks everyone for all of the support throughout the last few months. I’ll still be following.
Hey there! Submit a bug report in the Index tab of the Pebble app and we’ll get you taken care of! Don’t leave us!!
Done! Thanks so much.
well, my index ring is not broken. I am noticing that the rubber around the corner. The corners of the button is starting to show gaps.
