How to get more Offline Speech Recognition Models
In the help section for speech recognition it says “If you’re not getting accurate results, try using any of the “-pro” fallback models in the “Manage Offline Models” menu.”
I only have one model to choose from (parakeet-tdt-0.6b-v3). How do I get more models, especially “-pro” models?
Hi there, thanks for pointing that out! I just updated that help page. There’s only one model at the moment. Is it not working well for you?
The problem I was having is that the cloud model wasn’t working most of the time and even when I used the offline as a fallback option it wouldn’t work, so I had to use the offline solely. The offline works, but it doesn’t translate numbers or time properly (they come out as “eleven thirty two” rather than “11:32”) which causes errors when using certain apps like Todoist. I just noticed that the option of Rebble dictation has been added and now the Rebble dictation with offline as a fallback option is working perfectly.
Could you report a bug in the app? That would help us track down the issue with speech recognition not working. Thanks!
