Feature Request: Bluetooth Connection Lost to the Phone
In this case the phone must CRY (vibrate and make a lot of noice with the speaker):
C_O_N_N_E_C_T_I_O_N___L_O_S_T
(or similar)!
AND IT MUST DO THIS UNTIL I (the user) HAS CONFIRMED, THAT HE HAS NOTICED THAT(!) with e.g. a key press (which one? Upper, Middle, Lower?).
Unfortunately it seems that the reach of Bluetooth connections is now much more than the guaranteed 10 meters. So the alarm most often comes too late :frowning:
It would be best if the functionality of the app BT Guard - Pebble Appstore plus (at least optionally) a loud sound (on Pebbles which support sound) would be directly implemented in the Pebble OS.
This is because the BT Guard is a background app and there can be only one background app unfortunately. Why(!) the OS from which Pebble OS is derived, FreeRTOS, allows preemptive multitasking. It would be better to define a memory limit for all background apps and only if this is reached, no other background tasks (background worker) can be started.
Please note my name comes from Sinclair QL from 1984. It had a Motorola 68008 processor with 7.5 MHz and 128 KByte RAM (from which 32 KByte where the screen/display memory!) and it supports preemptive multitasking. Even the PSION handheld computers starting at the PSION 3 supported preemptive multitasking.
Good times! One of my first computers was a Sinclair ZX80 back in 1982.
