Charging stand for Pebble Time 2
Hello everyone!
I found that charging my Pebble Time 2 wasn’t very convenient. The charging cable was hanging awkwardly over the edge of the table, and the watch could easily slip out of the charging connector.
So, I designed a charging stand with a holder for the charging connector. It’s also much more convenient for checking notifications without having to look all the way down at your wrist.
I’ve already noticed a few imperfections, and I’ll update my model to address them. But if you’d like to create your own version or download mine and 3D-print it, feel free to check out my Onshape project and create your own fork, or simply download the STL file and print it yourself!
UPD. There’s a new version of stand that can be downloaded from the same link in previous paragraph.
The logo you used is from another watch brand called pebble lol.
Yeah this one https://www.pebblecart.com/
oops will correct, thanks for info
Hello there, thanks for comments about logo.
In 24 hours this model evolved from version 1 to version 6. You can download the newest stl file from the link on the original post. Now it looks like this
It looks good I might use it. The logo is right now!
I’m using this one: https://www.printables.com/model/1270373-pebble-charging-stand
fits great for the pt2 and this cable: Amazon.com: kwmobile Charger Cord Compatible with Pebble 2SE / 2+ / Time/Time Steel/Time Round - Charger for Smart Watch USB Cable - Black : Electronics
Genuinely, THANK YOU! The model looks both very nice and functional! I will be printing this in the next week! I really appreciate you sharing this!
You are a class act!
Hi, just added this model to MakerWorld for bambulab printers, feel free to print :slight_smile: https://makerworld.com/en/models/3432576-pebble-time-2-charging-stand#profileId-3913636
Could you be so kind as to make a mirrored version as well – I wear my Pebble on my right hand – so I see everything upside down :wink:
It holds upside down, just in case :sweat_smile:
Not the most elegant way of using it … :rofl: Looks pretty insecure …
Hello, i’ve done version for right handed users. You can see this version on photo.
I already corrected hook for leash and made stand higher, not sure if i will print new version. Those “stairs” are because i printed this as usual print, not good looking one.
I know, it doesn’t look much pretty so as before- feel free to make your fork of my project on Onshape. If you find this model interesting and worth printing- please download this model on Printables or MakerWorld.
Peace!
So fifth time is a charm, now stand feels the most reliable.
If you find this design convenient, feel free to download the latest model from Printables or MakerWorld.
