Changing the battery in a classic Pebble Time
While I wait for my Pebble Round 2 to arrive, I’ve dug out my old Pebble Time. It’s very cool to be able to connect it to the new app and use it again. However, it’s been in storage for a while and the battery doesn’t last very long (about 3 days). Is it possible to replace the battery, and how hard is it?
It is possible, decently straightforward if you have experience soldering and working with electronics.
Fwiw 3 days is about what I’d expect from a Time. Maaaybe 4–5 if you’re really good about conserving battery
My old Time used to give me 7 days easily when it was new, up to 9 if I was careful. You sure you’re not thinking about the old Round?
Nope! This was after replacing the battery though, and I know the aftermarket batteries are a little smaller than tock ones so that haye have been a factor too. It may have also been running a relatively battery-draining face :person_shrugging:
Hmm. If a new battery only gives me what I already have, I might leave it as it is…
